gemad
#1 Posted : Sunday, June 26, 2011 12:51:56 PM(UTC)
gemad
Toxic Smoke...took days to clear from the house. No Flames..plenty of hot spots around the lower left side cabinets.
Cleaned the inside rear filter, but I don't think that is the reason.
I suspect it's a motor problem, but not sure.
Should this dishwasher be thrown away. It runs and does not leak.
I feel very unsafe with electrical power to this unit....I'm having to wash dishes , the old fashioned way...and I thought I was a big shot...not a dishwasher !
#2 Posted : Monday, June 27, 2011 2:18:21 AM(UTC)
I could not find any tech info on the given model number.
If it is a non USA model I probably will not be able to.
If you cannot find the what and the why it overheated and be able to fix it properly, I would scrap it.
I think Beaumark is actually a GE but am not sure.
Try to contact them or search to see if this unit is part of a recall.
There have been several recalls over the years covering lots of different manufacture's units with overheating/electrical problems.
gemad
#3 Posted : Monday, June 27, 2011 4:10:18 AM(UTC)
gemad
Thank you denman....I needed some guidance. Sounds like good advice.
