spankee1
#1 Posted : Thursday, June 23, 2011 7:31:24 AM(UTC)
spankee1
Pot''s and pan light flashes w/door is closed but won't start. Other light's come on w/button are pushed?
#2 Posted : Sunday, June 26, 2011 4:08:21 AM(UTC)
Replacement parts for DUL140PPQO models | AppliancePartsPros.com
Could be a stuck key, see the tech sheet.
Normal way to troubleshoot is to check the keypad (control panel) with a meter. If it is OK then odds are the control board is the culprit.
Still a bit of a crap shoot but your odds are better5.
File Attachment(s):
DUL140.pdf (173kb) downloaded 4 time(s).
