Pot''s and pan light flashes w/door is closed but won't start. Other light's come on w/button are pushed?
Here are your parts Replacement parts for DUL140PPQO models | AppliancePartsPros.comSee the attachment for the tech sheet. Could be a stuck key, see the tech sheet. Normal way to troubleshoot is to check the keypad (control panel) with a meter. If it is OK then odds are the control board is the culprit. Still a bit of a crap shoot but your odds are better5. |
THIS FORUM IS DEAD!!!!!!! |
