elkski
#1 Posted : Thursday, October 25, 2007 7:57:18 AM(UTC)
elkski
S/N A1455441KH
Dryer is not heating at all on any setting even with vent hose open on the back.
I have taken off the access covers. the main 220 terminal looks ok. I have tried to take off screws thinking the whole 3 sides would come off to provide access.
The parts check says that the heater assy. is AP277083 and might as well get a new belt as I feel some rough spots. P/N AP3988821
I was going to hook up a meter to check to see of the heater terminals are getting power?
In holding pattern now.
elkski
#2 Posted : Thursday, October 25, 2007 9:17:30 AM(UTC)
elkski
well it appears this site is slow to respond if you are used to an hour time.. Maybe it takes the evening shift to respond.
anyway I got the front panel off and might have found my main problem. The ground wire from the dry sensor might have been off or came off when I took the door off? I still want to replace the belt... Not sure how I will get it around the drum??
elkski
#3 Posted : Thursday, October 25, 2007 10:21:02 AM(UTC)
elkski
Not so lucky as the loose sensor wire. must have knoced it off when removing the front the spade was very loose so I thought that was it.
No luck it is a broken heater coil..
