kjp
#1 Posted : Friday, November 28, 2008 9:50:29 PM(UTC)
kjp
DRYER MOTOR RUNS, TIMER WORKS,HAVE CONTINUITY AT ALL THERMALS AND ELEMENTS, and when 1 probe is left on the red wire on the timer,the other probe loses the continuity at the red wire that goes into the machine to the motor terminal(according to the schematic from the unit, it goes to 'operating thermostat'.
do i need new motor, or is there another component in or on the motor?
#2 Posted : Saturday, November 29, 2008 1:51:52 AM(UTC)
Did you remove the wires from at least one side of any device you were measuring for continuity (thermostats etc.)?
You must do this to ensure you are not reading an alternate/parallel circuit path and not just the device.
There is a good sticky at the top of this forum.
jtowntbo5@yahoo.com
#3 Posted : Saturday, November 29, 2008 5:03:31 AM(UTC)
jtowntbo5@yahoo.com
It's also possible your only receiving one leg of the 220 plug. 110 of the electricity is used to run the motor, and the other 110 is used to heat. Check breaker box to ensure nothing is tripped, then check for voltage at both legs of the plug.
kjp
#4 Posted : Saturday, November 29, 2008 5:45:45 AM(UTC)
kjp
It's also possible your only receiving one leg of the 220 plug. 110 of the electricity is used to run the motor, and the other 110 is used to heat. Check breaker box to ensure nothing is tripped, then check for voltage at both legs of the plug.Today 05:51 AM
denmanDid you remove the wires from at least one side of any device you were measuring for continuity (thermostats etc.)?
There is a good sticky at the top of this forum.Today 01:50 AM
I do have 250v actually, motor runs and timer switch works, just not heating. yes I did disconnect each component(btw i am an electrician of 25 years,so not new to troubleshooting,) each piece is fine, except there is no continuity through the two red wires going thru the motor connector when plugged into the motor, however motor runs fine
cpatterson
#5 Posted : Saturday, November 29, 2008 8:13:15 AM(UTC)
cpatterson
what you need to do is to buy a new heater coil and that should take care of it.If that dosnt the only other thing that might be wrong with it is a lose wire.hope you get it fixed soon.
#6 Posted : Saturday, November 29, 2008 9:01:21 AM(UTC)
Is this your wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203406688.pdf
Not sure where you are putting your meter leads on the motor switch.
One lead is on Timers Switch 2 R but what side of the motor switch is the other lead.
If on the heater side then something is open through the heater/thermostat circuit and should be easy to isolate.
If on the line side then an open is normal. The centrifugal switch does not close till the motor gets close to operating speed.
kjp
#7 Posted : Saturday, November 29, 2008 10:03:15 PM(UTC)
kjp
that is the diagram, and it makes sense about the switch,but when the unit is running all terminal thruout the circuit read 120v to ground, and 0 volts across each thermal, heatercoil, etc.
#8 Posted : Sunday, November 30, 2008 1:36:46 AM(UTC)
The 120 to ground really does not tell you much.
Lets say the centrifugal switch is not closing, then at all points you are measuring L1 to ground. If the switch does close then you are measuring L1 to ground on the right side of the heater and L2 to ground on the left side.
The 0 volts across the heater does indicate that the centrifugal switch is the most likely culprit.
I would remove the two heavier red wires from the motor's centrifugal switch, short them together, tape them up so they cannot short to ground and give it a try. If you get heat then you know the switch is blown or the centrifugal mechanism is not closing it. The switch itself is not available so the only way to fix it is a new motor.
Here are the parts
Model LER4634EQ1
If the above does not give heat then all that is left in the circuit is the timer re: TIMER SWITCH 2 R contact is not closing. It would give the same symptoms except now the 120 you measure is L2 to ground. You probably have already checked this for continuity so that is why I am going with the centrifugal switch.
Whirlpool Dryer runs but no heat (Dryer Repair)
by TeresaE 12/21/2008 1:06:21 PM(UTC)
