I have a problem! the fridge cools fine, the freezer won't cool down below 18 degrees. There is ice on the inside back wall of the freezer. I took everything out to defrost it with a hair dryer on the fins. I've plugged it back it, and it is cooling down but the fins (coils) are already iced over after 30.min. ! What is wrong? And how do I remove the inside back panel? I see the 4 screws but it still wont come out! Do I have to remove the bracket guides for all the selves as well? Help! The wife is getting upset!
Got the back cover off! It was packed with ice, I defrosted it. I've since started it up again and it's cooling. I do have white frost forming on the coils, is this normal?
Yes, a light snow is normal, compacted snow/ice is not. Take a look at the defrost heater at the bottom of the coils, if it is blackened inside the glass, you will need a new heater.
Didn't notice if it was black. It's not warm to the touch if that means anything. I already put the cover back on. I guess I'll have to wait and see if it gets like it was before. then I'll have to take the cover off again. Before I defrosted it, it was frozen and packed solid with ice. could that have an effect on it not working right?
Yep, when it has that much ice on the coils, air cannot be pulled through the coils, therefore the temps start to rise. So in about 7 days, you will have the buildup of ice again on the coils and will have to defrost again. Take a look at the heater, better yet, do a continuity check and see if it is good or bad. The heater only get's hot when it defrosts, it is not hot all the time, about once a day it will defrost, if not mark down on the calendar about 7 days from now, you'll be defrosting it again.
This upcoming Saturday will be 2 weeks, so far so good! Freezer temps are where they should be. I'll keep an eye out on it and keep my fingers crossed! Thanks to all that helped!
Now my freezer has temps anywhere from 2* to 14* throughout the course of a day. and it's not because the freezer has been opened alot. Any ideas?
When defrosting a few weeks back, i used the blow dryer and I must have directed it at the temp sensor on the side of the freezer. now the freezer cools, but temps will jump between 2* and 18* in a matter of hours! Could I have damaged the temp sensor?
