Originally Posted by: bandman1 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif)
Used the dryer one more time before taking it apart to clean it and now it will not light. Disassembled it, cleaned it and did see some carbon but now I can't get the dryer to light. What is the problem now?
Bandman,
You didn't turn the gas supply off or anything like that, yet ?
We're going to need to observe the ignition procedure, so we have a better idea of what's happenning.
There's two(2) ways to go, You'll need to be careful, either way.
1.) Remove the 1 X1 inch square plastic cover attached to the front panel.
2.) Start the dryer in a heat cycle, preferably on the highest heat setting.
3.) Using the peep hole and listenning closely,
a, You should hear a click, when the dryer is started.
b, In a few seconds, you should see the igniter start to glow, orange.
c, After 20 to 30 seconds of glow, you'll hear another click, the igniter
glow will start to fade, and the burner gas should ignite and produce a
flame.
You can do the same test, once you remove the front panel, drum, etc. and bypass the door switch, to make the unit operable.
I think we have a coincidental, failure.
Let us know what you observe, and we can get you going from there.
Good Luck,
