donna o
#1 Posted : Friday, November 28, 2008 6:59:06 AM(UTC)
donna o
I had the control panel replaced about 5 yrs ago. It started beeping and throwing a code. Anyway about 1 yr ago my oven would not stay on. I set it to 350 on Bake or convection(It doesnt seem to matter) and It appears to start but shuts down after a few seconds. For no apparent reason after a few months I tried it again and it worked fine. I was able to use it for about 6 mths. Well its doing it again. samething. I have tried it several times over the past few mths but it wont stay on.. Im hoping someone can help. The top of the stove works fine. I just hope its not the control panel again.
#2 Posted : Friday, November 28, 2008 1:41:04 PM(UTC)
Most likely the problem is a bad control board (aka a timer).
- The part number for the timer is AP4283393
Here are the break down diagrams for the Jenn Air range Model S176B
donna o
#3 Posted : Friday, November 28, 2008 2:46:58 PM(UTC)
donna o
Thanks for the info..Is it possible to test the Timer. The display and clock still work. Also is it a Do it yourselfer job.
#4 Posted : Friday, November 28, 2008 3:54:12 PM(UTC)
If you know how to handle a simple tools, you probably can do it.
You can find the disassembly instructions in the Service manual.
Guest (4)
