I had the control panel replaced about 5 yrs ago. It started beeping and throwing a code. Anyway about 1 yr ago my oven would not stay on. I set it to 350 on Bake or convection(It doesnt seem to matter) and It appears to start but shuts down after a few seconds. For no apparent reason after a few months I tried it again and it worked fine. I was able to use it for about 6 mths. Well its doing it again. samething. I have tried it several times over the past few mths but it wont stay on.. Im hoping someone can help. The top of the stove works fine. I just hope its not the control panel again.
Most likely the problem is a bad control board (aka a timer). - The part number for the timer is AP4283393 Here are the break down diagrams for the Jenn Air range Model S176BGene.
Thanks for the info..Is it possible to test the Timer. The display and clock still work. Also is it a Do it yourselfer job. Thanks
If you know how to handle a simple tools, you probably can do it. You can find the disassembly instructions in the Service manual. Gene.
