The ice maker makes ice but when I lift the ice maker arm to turn it off the water valve continues to run about every 5 minutes like it does when it fills but no water is being dispensed. Does this sound like a water valve problem or a problem with the arm?
Originally Posted by: billfla  ...the water valve continues to run about every 5 minutes like it does when it fills but no water is being dispensed... How did you know it runs if no water came to the ice maker? Water valve does not run every 5 minutes. It should run about once in an hour. Gene.
