my Maytag Atlantis washer will not despence cold water, i switched the cold & hot water in and still despences hot not cold. is the temp sencer bad or the push botton control for hot & cold washing suspect. the auto temp control light doesn't light up any more eather Thanks, Glenn
Well that is just plain weird, since unless you told it the machine doesn't know you switched the connections. I would try replacing the ATC board, this part here. Part number: AP4028021
