my Maytag Atlantis washer will not despence cold water, i switched the cold & hot water in and still despences hot not cold. is the temp sencer bad or the push botton control for hot & cold washing suspect. the auto temp control light doesn't light up any more eather Thanks, Glenn
Groups ready for retrieval: Senior Expert
Well that is just plain weird, since unless you told it the machine doesn't know you switched the connections. I would try replacing the ATC board, this part here. Part number: AP4028021
