jsmls
#1 Posted : Wednesday, November 26, 2008 6:12:08 PM(UTC)
jsmls
I have an old Whirlpool washer. Stops after wash cycle;does not drain, rinse or spin. Have turned timer selector switch to different cycles. It has turned back on to rinse and spin. Now, I can't get it past wash cycle. Some say try lid switch. I will replace. But it looks like selector dial may be bad?? Please advise.
Thanks, Joe
#2 Posted : Thursday, November 27, 2008 6:50:15 AM(UTC)
Try lid switch first, your timer is pretty reliable.
jsmls
#3 Posted : Thursday, November 27, 2008 9:23:34 AM(UTC)
jsmls
Thanks for the tip. Would you tell me how to lift top of cabinet? I see the selector panel folds back. There is a connection on each front corner. Do they just snap up?
Thanks,
Joe
#4 Posted : Thursday, November 27, 2008 12:27:22 PM(UTC)
Pry off both ripply spring retainers, unplug lid switch, and tilt outer panel away.
When putting back, make sure the slots in the bottom of the outer panel go in the frame tabs on the bottom.
#5 Posted : Friday, November 28, 2008 5:07:43 AM(UTC)
Uh, how many people read Chinese!!, probably none, or 1 %
