35mastr
#1 Posted : 17 years ago
35mastr
Everything works.Just does not heat up.Had the same thing happen 2 years ago and I just replaced it with this one.Please chime in with any and all troubleshooting advice.
35mastr
#2 Posted : 17 years ago
35mastr
Bump
Has anyone ever run into this problem??
#3 Posted : 17 years ago
Hi George
Does it make any unusual noises? If it does try to describe it.
35mastr
#4 Posted : 17 years ago
35mastr
Gene,It works just like it did when I pulled it out of the box when new.No abnormal noises or anything unusual.It just does not heat any thing up.Not even warm.All displays work,Lights inside Etc.Just will not heat anything up.
#5 Posted : 17 years ago
Sounds like the magnetron tube is bad. Do not touch anything and call Sears. The microwave is less then a year old and is under the warranty.
Microwave does not heat...buzzing sound (Microwave Repair)
by bnhmiles 13 years ago
Microwave Does Not Heat. (Microwave Repair)
by jpeterman12 18 years ago
