HarryAndrews123
#1 Posted : Tuesday, June 14, 2011 12:22:45 PM(UTC)
HarryAndrews123
Dishwasher fills up with water but wash cycle nothing happens. Water just lay,s there. Next cycle water pumps out, nextcycle water comes in fills up next cycle washcycle water just lays there nextcycle water pumps out next cycle rincecycle water comes in just lays there next cycle water pumps out took screen in bottom out cleanedit took cover off pump impeller is free
#2 Posted : Tuesday, June 14, 2011 3:44:55 PM(UTC)
Remove the bottom panel and check if the wash pump motor is working or makes any noise while the timer calls for wash. Post the results.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FDB221RFR2 Frg(v0) / 24 " Built - in Dishwasher | AppliancePartsPros.com
HarryAndrews123
#3 Posted : Tuesday, June 14, 2011 4:14:05 PM(UTC)
HarryAndrews123
when diswasher changes cycles it sounds like amotor humming during the wash cycle,and the main motor to the rear of the tub is running but water just lays there till next cycle then it pumps water out. harry123
#4 Posted : Tuesday, June 14, 2011 7:50:26 PM(UTC)
There are two motors in your dishwasher. One is the main pump motor (#70 on the diagram) and the other one is the drain pump motor (#60). So which motor is running and which one is humming?
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
