TS62152
#1 Posted : Tuesday, June 14, 2011 6:29:00 AM(UTC)
TS62152
I can't tell were the door switch (ap4114315) goes from the diagram?
Joe / APP Team
#2 Posted : Tuesday, June 14, 2011 7:07:11 AM(UTC)
Joe / APP Team
TS,
The door switches and latch assembly are located inside the door assembly.
You will need to remove the inner door liner to access the switches and latch assembly.
Here's some information that should help :
Removal of the Inner Door Panel will allow access to the
Microprocessor Board, Door Switches, Detergent / Rinse
Aid Dispenser, and Vent Assembly.
Removal
1. Disconnect power to the machine.
2. Open the Dishwasher door.
3. Remove the 11 Torx™ screws along the sides and top of the Inner Door Panel.
4. Separate the Inner Door Panel from the Outer Door.
5. Disconnect wires from the Vent and Dispenser Wax Motors before pulling the Inner Door Panel away from the Dishwasher.
Door Latch & Switch Holder Assembly
Two Door Switches are used in the Latch Assembly. Both switches are normally CLOSED and will open only when engaged by the Door Latch mechanism. Each switch is in series with respect to L1 and neutral line operations.
Failure of either or both switches will result in rendering
the Dishwasher inoperative.
NOTE:
Door Switches require no field adjustment.
Removal
2. Remove the Inner Door Panel. (See paragraph Inner Door Panel removal).
3. Lift Door Latch Assembly out.
Switch Removal
3. Remove Door Latch and Switch Holder Assembly.
4. Depress locking tabs and lift switch from holder.
Good Luck,
LG LMV1680ST Microwave Door Switches (Microwave Repair)
by ctalbert150 6/13/2024 7:19:37 AM(UTC)
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Frigidaire Refrigerator LGHT1846QP1 - door switch and cabinet cooling (Refrigerator & Freezer Repair)
by BJPrice 10/26/2020 5:28:12 AM(UTC)
Maytag MVWC4658W2 Door switch? Will drain but not spin. (Washer Repair)
by JimAlbr 6/4/2020 5:49:53 PM(UTC)
Dryer keeps blowing the DOOR SWITCH?!?! (Dryer Repair)
by ppipowerclass 12/3/2017 12:54:14 PM(UTC)
Door switch (Dryer Repair)
by Hoglover 4/7/2017 2:37:33 PM(UTC)
Whirlpool Door Switch Replacement- lost power to microwave (Microwave Repair)
by jk071604 3/23/2017 4:55:46 AM(UTC)
door switch (Dryer Repair)
by Cole B. 8/28/2016 10:26:07 AM(UTC)
How to remove the door switch (part #AP4442085) (Refrigerator & Freezer Repair)
by rannug 4/20/2016 10:12:10 AM(UTC)
wiring for maytag door switch (Dryer Repair)
by macjane94 5/29/2015 10:25:15 AM(UTC)
Door switches not operating properly (Microwave Repair)
by restlesssailor 4/19/2015 12:21:54 PM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
How do I disconnect door switch? (Dryer Repair)
by ocampon 12/12/2014 3:18:51 PM(UTC)
Can't put the freezer door switch back! (Refrigerator & Freezer Repair)
by bzk 5/13/2014 5:22:07 PM(UTC)
