Keith K.
#1 Posted : Wednesday, November 26, 2008 6:44:06 PM(UTC)
Keith K.
Dishwasher had quit working. I diagnosed issue with Control Switch and ordered replacement part from your company. I just installed the part (9741522).
When I try to start wash cycle in Pots mode or Normal mode the dishwasher just stays with heating water light lit (over 20 minutes). Wash cycle does not start.
When I start it in Light/China mode it works great. It goes from Heating Water to Wash cycle starting pretty quickly.
Any idea why I'm having an issue with the first two wash cycles?
These two cycles have not operated for quite some time.
Thanks!
#2 Posted : Thursday, November 27, 2008 1:56:35 AM(UTC)
Here is the parts breakdown
Model KUDA230YWH2
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%209741531.pdf
Could be related to the water temperature. The machine is waiting for the water to heat up to a set level before starting the wash. Check to see if the heating element is working.
Be careful do not burn your fingers.
Check the element and thermostats for continuity with a meter. Remove the wires from one side of the device you are checking.
Heating element should be around 10 ohms.
Thermal cutoff thermostat should be closed at room temperature.
Could also be a low water level in the tub, the tech sheet gives the required level.
Keith K.
#3 Posted : Thursday, November 27, 2008 7:31:03 AM(UTC)
Keith K.
Thanks for the suggestion.
I'll check the heating element. I guess what has thrown me off is why the dishwasher works in the Light/China cycle but not the other two wash cycles.
Is it the same heating element that heats up to dry dishes? Dishwasher is steamed up and drying very well at completion of cycle.
#4 Posted : Thursday, November 27, 2008 1:32:33 PM(UTC)
Looks like there are 2 heaters.
The wiring diagram in the tech sheet shows an AIR heater for drying and a WH heater which I think is the Wash heater.
