jimmydye@ca.rr.com
#1 Posted : Monday, June 13, 2011 11:18:14 AM(UTC)
jimmydye@ca.rr.com
My Ice maker is putting out ice but at a slow pace but it is spilling water out of the front corner of the ice makers front tray like a 1/4 inch frozen stream. Do I need a hole ice maker or is this an adjustment issue????
Thanks, Jim
Joe / APP Team
#2 Posted : Monday, June 13, 2011 11:33:39 AM(UTC)
Joe / APP Team
Thanks, Jim
Jim,
You can try and adjust the water level, it will work for a while, but you've most likely have a "sticky" water valve and it's allowing the icemaker to slowly overfill, and causing the icicle.
With the white plastic cover removed from the front of the assembly, you should see a white plastic screw slightly protruding from the side of the mechanism. you can adjust the level lower by turning the screw in a clockwise direction 1 or 2 revolutions (3/4 to 1 turn would probably be sufficient).
I take for granted you've already checked for good water supply to the fridge and a clean water filter( if applies).
Good Luck,
