Washer Shows F02 Code Or Sd Code In Past This Has Meant Something Was Clogging Drainage System This Time No Clog I Took Everything Apart Both Boot Drain Hose And Replaced The Pump There Is Nothing Clogging System What Else Could Cause These Code That Stop Washer?
If you have suds or a kinked hose that makes the drain out more than 25 seconds, it will give this error msg. Not too sure of the 25 seconds, but just time it and post.
