sbabler
#1 Posted : Sunday, June 12, 2011 1:19:39 PM(UTC)
sbabler
The dryer was tripping the breaker and now it just heats glowing hot on each temp cycle until i assume the thermal overload shut it down. After it cools a bit it starts heating all over again. What up with this? Thanks.
#2 Posted : Monday, June 13, 2011 1:05:46 AM(UTC)
Replacement parts for WHIRLPOOL TEDS840JQ2 DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
You may have a grounded element.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on all temperature settings.
File Attachment(s):
TEDS840.pdf (190kb) downloaded 2 time(s).
