000071
#1 Posted : 16 years ago
000071
Have an Amana side by side refrigerator, approx. 11 years old. Both refrigerator & freezer sides have very low cooling. Freezer does not freeze food. Has been getting progressively worse over time. Everything seems to be working fine, except that the top most coil tube in the freezer, behind the panel, & the switch (defrost thermostat ?) clipped onto the tube build up quite a bit of frost. Could the switch be bad, and could this cause the low cooling in both the fridge & freezer ?
v2k04
#2 Posted : 16 years ago
v2k04
is the whole coil frosted or just an iceball at the beginning and rest of coil is dry ?
000071
#3 Posted : 16 years ago
000071
Just the top most tube & switch. The rest of the tubes are not frosted & are not very cold.
v2k04
#4 Posted : 16 years ago
v2k04
It has a leak or a restriction or an inefficient compressor or all three it's not worth fixing
000071
#5 Posted : 16 years ago
000071
Thank you for the info. It will save a lot of time, trouble & effort. It is appreciated.
