tin
#1 Posted : Friday, June 10, 2011 3:21:01 PM(UTC)
tin
All selection LEDs will light when indicated except the "Normal Wash". But no matter which cycle is selected, none will start dishwasher. I had repairman verify door latch & power good. He says it's either the control panel or control board. Any way to know which? Unit is less than 2yrs old.
#2 Posted : Saturday, June 11, 2011 2:03:00 AM(UTC)
Replacement parts for MAYTAG MDBH945AWB3 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
And finally here is a manual for this series of units
16021814 Maytag Jetclean II Dishwashers Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
Have you tried unplugging/removing power from the unit for 5 minutes to see if the board will reset?
You could try the diagnostics to see if anything pops up.
If neither of the above helps then the usual way to trouble shoot is to check the control panel keys with a meter (see the tech sheet), then if it fails replace it. If it passes then replace the control board.
Still a bit of a crap shoot but your odds are better.
You may want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
File Attachment(s):
MDBH945.pdf (893kb) downloaded 12 time(s).
tin
#3 Posted : Sunday, June 12, 2011 6:38:01 PM(UTC)
tin
When I pulled the control panel to clean the ribbon strip connections, I noticed several of them were blackened. Pretty sure that's my trouble. I will order the part and let you know. Thanks again.
Originally Posted by: denman Go to Quoted Post
Unplug the unit
Open it up
my dishwasher won't start a cycle (Dishwasher Repair)
by Guest 1/13/2023 9:06:08 PM(UTC)
Frigidaire dishwasher won't start, all lights are blinking (Dishwasher Repair)
by Guest 11/22/2021 4:33:30 PM(UTC)
Frigidaire Dishwasher Won't Start (FFBD2406NS9B) (Dishwasher Repair)
by Radamis 8/3/2020 8:14:55 AM(UTC)
Viking DDB325SS Dishwasher won't start (Dishwasher Repair)
by tmman 6/10/2020 6:44:15 AM(UTC)
Bosch dishwasher won't start after power surge (Dishwasher Repair)
by Larry120 7/17/2018 11:07:27 AM(UTC)
Bosch dishwasher won't start -- display flashes time (Dishwasher Repair)
by rsilk 6/28/2018 6:21:47 PM(UTC)
Dishwasher won't start when house is too cold (Dishwasher Repair)
by manshack_one 1/2/2018 8:13:29 AM(UTC)
dishwasher won't start (Dishwasher Repair)
by goosemasterkl 9/6/2017 5:03:10 PM(UTC)
Ge dishwasher won't start (Dishwasher Repair)
by gegerva 10/9/2016 5:45:31 AM(UTC)
GE dishwasher won't start (Dishwasher Repair)
by tyanbinh 6/10/2016 7:01:58 PM(UTC)
Dishwasher won't start cycle (Dishwasher Repair)
by fugue 4/16/2016 4:33:36 AM(UTC)
Maytag dishwasher won't start unless I manually hold door closed (Dishwasher Repair)
by RepairKing53 1/29/2016 10:14:13 AM(UTC)
by Tricjabs 1/26/2016 5:41:06 PM(UTC)
by Strum310 11/15/2015 5:57:23 PM(UTC)
by dhbrittain 9/9/2015 3:35:11 PM(UTC)
