jmalcolm@cal.berkeley.edu
#1 Posted : Thursday, June 9, 2011 12:46:44 PM(UTC)
I need to replace the hot and cold water inlet valve assy. How do I gain access to the inside of the rear panel?
Joe / APP Team
#2 Posted : Thursday, June 9, 2011 1:20:48 PM(UTC)
Joe / APP Team
You will need to remove the complete cabinet assembly,
Here's how.
*** unplug the power cord and turn the water faucets Off, FIRST ***
1. Remove the two Phillips-head screws securing the front corners of the console to the washer top.
( The console screws can also be located on the backside of the end caps, under the end cap trim panels on the front of the cap, and newer models have spring clips in the seam between the end cap and top).
2. Tip the console back on the hinges that secure the top of the console to the washer back.
ACCESSING COMPONENTS INSIDE THE WASHER CABINET
Components inside the washer cabinet can be accessed by completely removing the outer cabinet as one unit.
1. Remove the console mounting screws and tilt the console into the service position.
2. Unplug the lid switch harness connector from the receptacle in the washer top.
3. Remove the cabinet mounting clips by placing the flat blade of a screwdriver in the clip.
4. Remove the cabinet by tilting it forward and pulling it away from the washer.
5. The rear panel can be tilted back for additional access to components at rear of machine by twisting the rear panel support 90°. and then tilting the rear panel back.
Remove cabinet to access drain pump & hose (Washer Repair)
by Hpaul 2/25/2011 3:40:09 PM(UTC)
remove cabinet (Dryer Repair)
by tforgey 7/2/2009 2:19:08 PM(UTC)
How do I Remove cabinet to get to pump (Washer Repair)
by edmgriffin 4/13/2009 5:39:21 AM(UTC)
Remove Cabinet Kenmore Washer Mod. 110-15942401 (Washer Repair)
by Jake12 5/7/2008 5:39:13 PM(UTC)
