tforgey
#1 Posted : Thursday, July 2, 2009 2:19:08 PM(UTC)
tforgey
I need to replace the heating element but I don't know how to remove the cabinet. The filter is on the front.
applianceman
#2 Posted : Thursday, July 2, 2009 2:52:20 PM(UTC)
applianceman
You remove the bottom front panel (under the door) by pressing in on two clips in-between the panel and the door. Once off you should see the element on the right under the drum. Hope this helps! Clothes Dryer Repair Guide
kayakcrzy
#3 Posted : Friday, July 3, 2009 4:13:49 AM(UTC)
kayakcrzy
The clips that he is talking about, are at the top of the bottom panel, about 4 inches from each end. It is best to slide a putty knife in there, and it will release the front real easy. Tom ApplianceEducator.com
Remove Cabinet (Washer Repair)
by jmalcolm@cal.berkeley.edu 6/9/2011 12:46:44 PM(UTC)
Remove cabinet to access drain pump & hose (Washer Repair)
by Hpaul 2/25/2011 3:40:09 PM(UTC)
How do I Remove cabinet to get to pump (Washer Repair)
by edmgriffin 4/13/2009 5:39:21 AM(UTC)
Remove Cabinet Kenmore Washer Mod. 110-15942401 (Washer Repair)
by Jake12 5/7/2008 5:39:13 PM(UTC)
