Dean Sheridan
#1 Posted : Monday, November 24, 2008 4:23:49 PM(UTC)
Dean Sheridan
It started only in the final stage after wash. I inspected the unit for integraty seemed to be intact. After placing on side and lubricating belt pully area it seemed to sovle problem for a week or two. Now even with no load the drumb spins vioalantly like a top banging all sides. I thought if the spring were week I could test it by holding on with top down and place in spin cycle. The action is so ruff I can not even hold it steady with two hands. new spring will not cure this. Is there a micoswitch for equaling out spin imbalance or could it be something else? Please advise.
#2 Posted : Tuesday, November 25, 2008 2:43:20 AM(UTC)
Pull front cover off and look for white shavings on the washer bottom.
Dean Sheridan
#3 Posted : Tuesday, November 25, 2008 5:09:49 AM(UTC)
Dean Sheridan
None. No plasctic scrappings or powder. I seem to be able to use the unit but onlt with small loads. Even at that it "ticks" the sides of the box. All else seems normal.
#4 Posted : Tuesday, November 25, 2008 5:49:50 AM(UTC)
I assume this is an Atlantis top loader. If so, does the tub lean to one side, maybe you have a busted spring.
