robertmach@hotmail.com
#1 Posted : Wednesday, June 8, 2011 10:18:50 AM(UTC)
TRying to find out what error code F5 means on Kenmore HE4t front loading washing machine means
Will start wash cycle, about 5 minutes in will stop and present error code F5
Joe / APP Team
#2 Posted : Wednesday, June 8, 2011 12:13:54 PM(UTC)
Joe / APP Team
Robert,
The F5 error code indicates a water temperature problem. The control board circuit is not recognizing a resistance change in the water temperature sensor.
You most likely have a loose connection at the tub sensor , or a bad heater.
Part number: AP3128829
Part number: AP3865677
( the replacement heater has both components pre mounted to the bracket)
You can gain access to both components by removing the lower access panel, both parts are secured to the bracket, at the 6 o'clock position on the front of the outer tub cover.
Good Luck,
Markram
#3 Posted : Tuesday, March 13, 2012 2:52:27 PM(UTC)
Markram
Once you locate the heating element and the water temperature sensor you will want to take resistance measurements of them both.
Unplug unit, remove wire connections to water temperature sensor and heating element. Set your multimeter to measure resistance... Ohms, and test the temperature sensor, if it is infinite resistance - then the sensor is open, and has failed. If it reads resistance... following is normal...
Temperature of sensor... approx.
32 F resistance should be 35.9k ohms
85 F resistance should be 9.7k ohms
104 F resistance should be 6.6k ohms
Basically it should be around 8k ohms to 5k ohms.... and if it is, then it tests ok per manufacturer specs.
The heating element should not read infinite resistance or it has failed. Otherwise it should read approximately 6 to 9 ohms, maybe a little higher...
If one has failed, replace it. If both pass tests, then check all connections and wires on control board and both sensor and element...
It is possible that it is the control board, but you will want to start with those components first.
good luck
