merple
#1 Posted : Wednesday, June 8, 2011 10:41:51 AM(UTC)
merple
The lights on my dishwasher are messed up...I tried a "reset" which originally worked. Now, all I get after any reset efforts (heat, normal twice or unplug, heat, hi-wash) is a switch between normal and rinse only...rinse eventually wins out. After it runs for about 20-30 minutes (in rinse), the lights go out completely (until resetting).
No cancel, start, any other buttons are functional.
Would changing the control panel take care of this problem and (hopefully) restore regular operations?
Joe / APP Team
#2 Posted : Wednesday, June 8, 2011 11:57:51 AM(UTC)
Joe / APP Team
Merple,
That would be the first place to start, based on your post.
Part number: AP3951373
You most likely have a bad keypad circuit.
You'll still need to run the "reset" program after you change the control panel.
Good Luck,
Replace control panel? (Dishwasher Repair)
by chezfritz 12/19/2007 11:10:03 AM(UTC)
