mc22
#1 Posted : Tuesday, June 7, 2011 7:06:35 AM(UTC)
mc22
I have a Whirlpool Front Loading Washer and over the past few weeks I have noticed that my clothes have not been as dry as usual after the cycle has been completed. Last week I went to do wash and the washer just shut off in the middle of the cycle, I kept hitting start to continue but it would only work for about a minute than stop again. Then all of the lights started blinking so I unplugged it tried plugging it back in and wouldn't work. I also noticed that before the cycle started I had to open & shut the door a few times before it would register. After it stopped the final time I had to take towels and soak up all of the water left in it. The washer is no longer under warantee so I was wondering if anyone knows if this is something easy I can fix on my own before I put out money to have someone come out and look at it. Thanks in advance!
sidfink43
#2 Posted : Wednesday, June 8, 2011 5:29:53 PM(UTC)
sidfink43
Look inside the lower service panel or under the top for tech notes that will show you how to put it into diagnostic mode.
First check the pump and drain hoses for obstructions. They clog up and cause problems like yours.
Guest (4)
washer stopped working in middle of cycle (Washer Repair)
by kmpadilla 6/16/2013 8:09:59 AM(UTC)
