kitv
#1 Posted : Friday, November 21, 2008 5:08:26 PM(UTC)
kitv
My dryer won't start. A "repair man" directed me to the fuse, but when looking at parts manual on line the thing he told me was the fuse is called the thermal limiter.......is that the same as a fuse and would that keep the dryer from coming on?
Drags1998
#2 Posted : Friday, November 21, 2008 5:28:08 PM(UTC)
Drags1998
Yes, Its #36!!!!! If you have a meter, check it for contineuty(sp) it should read closed, If you have NO meter, UNPLUG the dryer, pull both wires off the limit thermostat, connect the 2 wires together, tape them up and try to start the dryer, If it starts,replace the #36!!! DO NOT leave the dryer running without this part working correctly!!!!!:)
kitv
#3 Posted : Friday, November 21, 2008 6:03:48 PM(UTC)
kitv
Thank you so much I will give it a try!
#4 Posted : Saturday, November 22, 2008 12:43:46 AM(UTC)
Thermal fuses blow if the dryer has a bad cycling thermostat, or clogged ducting. Before replacing fuse, measure the dryer temperature and make sure it is not higher than say 160 degrees.
Electrolux Dryer Outlet Thermal Limiter keeps failing (Dryer Repair)
by gawhaler 11/26/2014 5:49:42 AM(UTC)
Thermal Limiter (Dryer Repair)
by laabsdan 12/6/2011 12:50:53 PM(UTC)
Dryer Heat On Then Off (element,thermostat, or thermal limiter?) (Dryer Repair)
by KJW 11/21/2010 10:54:47 PM(UTC)
Thermal Limiter Help (Dryer Repair)
by Zankou 10/8/2010 6:27:32 AM(UTC)
Where do I find my Thermal Limiter? (Dryer Repair)
by Repaircaveman 5/13/2010 2:29:28 AM(UTC)
how to test Thermal limiter (Dryer Repair)
by pcalnc 5/26/2009 5:14:00 PM(UTC)
thermal limiter (Dryer Repair)
by savage1964 5/5/2008 1:05:39 PM(UTC)
kenmore laundry center thermal limiter (Dryer Repair)
by sunshine5500 1/15/2008 10:58:11 AM(UTC)
