dreeves
#1 Posted : Friday, November 21, 2008 7:53:40 PM(UTC)
dreeves
The Kenmore gas dryer will only run if the Press-To-Start switch is held down.
libertyappl
#2 Posted : Saturday, November 22, 2008 6:55:53 AM(UTC)
libertyappl
Your start switch is probably out, replace it. Part Details - WHIRLPOOL Pusht to start switch, part number: 3395382
Nat
kayakcrzy
#3 Posted : Sunday, November 23, 2008 4:25:50 AM(UTC)
kayakcrzy
If you replaced your start switch, and that did not do it, it will be the microcomputer board, that is located behind the control panel. Part # Part number: 8546223
. Tom
#4 Posted : Monday, November 24, 2008 2:27:08 AM(UTC)
This dryer uses a cheap power relay that likes to fail and blow out the microcomputer.
Advise to replace both microcomputer Part number: 8546223R
and the relay Part number: 3405281
If you want to keep this dryer, suggest getting someone to install a surge protector in the breaker panel.
dreeves
#5 Posted : Friday, November 28, 2008 7:49:13 PM(UTC)
dreeves
Are you referring to the motor relay or heater relay. They are the same part number. Thanks
#6 Posted : Saturday, November 29, 2008 12:36:41 AM(UTC)
They are interchangeable.
