weg
#1 Posted : Tuesday, May 31, 2011 6:26:53 AM(UTC)
weg
The washer works on all cycles but when it comes to the rinse, that water only drips in. I cleaned all hose filters but do not know if this is a major problem or worth a repair. Any advise???:confused:
sidfink43
#2 Posted : Wednesday, June 1, 2011 8:57:19 AM(UTC)
sidfink43
Since it fills correctly on the wash cycle I think the timer is the issue, for some reason it is not sending enough current to the valves to open them.
Try changing it out and see if that helps. If you need more info please post a full model number.
Good luck.
weg
#3 Posted : Wednesday, June 1, 2011 9:02:27 AM(UTC)
weg
Good luck.
I will get that info this evening, someone also said it may be a fuse from an unbalanced load....does that make any sense to you to try??
sidfink43
#4 Posted : Wednesday, June 1, 2011 11:49:00 AM(UTC)
sidfink43
Not on the Roper models that I am familiar with.
weg
#5 Posted : Wednesday, June 1, 2011 12:01:36 PM(UTC)
weg
Thanks...saves me the problem of looking for a fuse! I'm resently separated and trying to be self sufficent....any insight into this repair would be greatly appreciated! I'll find the model# and go from there :)
weg
#6 Posted : Thursday, June 2, 2011 7:57:11 AM(UTC)
weg
The model number is RAX4232KQ0
sidfink43
#7 Posted : Thursday, June 2, 2011 8:51:05 AM(UTC)
sidfink43
Ok, good. One thing you need to do before we go any further is to see if it will fill with cold water when you have it on cold water on the wash cycle. If not, this means the cold water valve is not opening, which is why you would not get a fill on the rinse cycle which only uses cold water.
If not check the cold water hose to make sure cold water is coming through it, and if so then the cold water valve may be the problem.
If cold water will fill in the wash cycle, then the timer is more likely the problemLet un.
No rinse water on spin cycle (Washer Repair)
by strawberry 4/26/2009 7:53:06 AM(UTC)
No rinse water (Washer Repair)
by DJ Scott 1/5/2009 7:23:49 PM(UTC)
