deevalerie
#1 Posted : Thursday, July 26, 2007 2:34:01 PM(UTC)
deevalerie
I need to replace an interior panel in my freezer door and need detailed directions on how to do this. Is there a manual available online?
Adam / APP Team
#2 Posted : Thursday, July 26, 2007 3:30:38 PM(UTC)
Adam / APP Team
Rank: Administration
Groups: Administrators
Dear deevalerie,
There are no detailed instructions available on line that I know of but I may be able to give you a general idea. It may take some time to replace it but you will save some money doing it yourself.
Click here for breakdown for us to refer to
( Take your time looking it over to avoid additional work )
1.First disconnect the wire harness for the dispenser along the bottom
2.( See diagram #3 ) You will have to start taking the door off by removing the top hinge screws #43 from the body and leaving the hinge #18 attached to the door.
3.Pull the door up and off, laying it on something soft on the floor.
4.( See diagram#6 ) You will have to then remove item #34 along with all the screws#15 and the retainers #13 under the lip of the gasket#14.
5.All other pieces from the old door will have to be used on the new door.
6.Reassemble in the opposite it was taken apart.
Click here for price, availability and part number for the inner freezer door liner.
GE Freezer door repair (Refrigerator & Freezer Repair)
by ajd 3/3/2008 7:15:31 AM(UTC)
