bpcolll
#1 Posted : Sunday, May 29, 2011 10:05:35 PM(UTC)
bpcolll
can anyone help with location of defrost timer?
#2 Posted : Monday, May 30, 2011 2:29:35 AM(UTC)
Replacement parts for ARB2117BS models | AppliancePartsPros.com
The defrost timer (Item 342 in Section 9) looks like it is behind the kick plate.
bpcolll
#3 Posted : Tuesday, May 31, 2011 9:45:01 AM(UTC)
bpcolll
Thanks. It appears the defrost timer is cycling. I need help accessing defrost heater and thermometer. Bottom freezer has sliding door. Do I need to remove slider mounting brackets by removing recessed screws? The cover plate where heater and thermometer is looks simple, just 4 sheet metal screws.
Test procedure for heater and thermometer would be appreciated.
Amana bottom freezer defrost problem (Refrigerator & Freezer Repair)
by gwetzler 11/6/2010 8:06:30 PM(UTC)
