can anyone help with location of defrost timer?
THIS FORUM IS DEAD!!!!!!! |
Thanks. It appears the defrost timer is cycling. I need help accessing defrost heater and thermometer. Bottom freezer has sliding door. Do I need to remove slider mounting brackets by removing recessed screws? The cover plate where heater and thermometer is looks simple, just 4 sheet metal screws.
Test procedure for heater and thermometer would be appreciated.
