My frigidaire refrigerator is not getting cold at all and freezer is actually defrosting. All other power seems to be fine (lights, digital readings, etc...) what do you think is my problem?
A model number may help others help you. Model Number LocatorAlso more info on the symptoms. What is running and what is not? Is the compressor cycling, never on or always on? What if anything have you done to troubleshoot the unit? |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: Jfezee  My frigidaire refrigerator is not getting cold at all and freezer is actually defrosting. All other power seems to be fine (lights, digital readings, etc...) what do you think is my problem? MODEL LFUS2613LFO I have not did any troubleshooting, dont know much about frig. Also there has been a number of storms, so thunder/lightning may be an issue!
Originally Posted by: denman  Thanks, i will go from here!
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
