jessclark1977
#1 Posted : Wednesday, November 19, 2008 8:00:44 AM(UTC)
jessclark1977
My washer will start to fill with water but will not move to any of the other cycles and i have it on the highest water level and it and it might not even get all of my cloths wet. Someone said it my be my drain hose not high enough could that be so.:confused:
magician59
#2 Posted : Wednesday, November 19, 2008 8:29:20 AM(UTC)
magician59
Check your lid switch. Open the lid and depress the switch with a small bladed screwdriver. Does it feel "spongy"? Do you hear and feel a defined click? Also check your water supply valve: Is it clogged or partially blocked with debris?
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
whirlpool washer model WFW6620HW2 Fried? (Washer Repair)
by justme56 2/11/2024 8:42:17 AM(UTC)
Whirlpool washer F20 code (Washer Repair)
by wstrick14 1/6/2024 3:42:34 PM(UTC)
Whirlpool washer clicking when filling (Washer Repair)
by RogeM 12/3/2023 8:13:49 AM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
whirlpool washer buzzer Way too loud! (Washer Repair)
by Guest 5/1/2023 11:33:43 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Whirlpool washer spins during drain cycle (Washer Repair)
by jsdscot 1/23/2023 5:04:07 PM(UTC)
Whirlpool Washer WTW5105HW1- Loud Spin Cycle- Spring/suspension question (Washer Repair)
by gabeTBP 1/21/2023 6:26:31 AM(UTC)
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
whirlpool washer fill and drain only (Washer Repair)
by Randero 10/14/2022 2:53:13 AM(UTC)
Capacitor for Front Load Whirlpool washer Model # wfw9550ww00 (Washer Repair)
by Guest 9/11/2022 2:49:05 PM(UTC)
