mptimoneil
#1 Posted : Wednesday, November 19, 2008 7:57:30 AM(UTC)
mptimoneil
I replaced a broken door handle latch and got the seven blinking lights when I went to start the machine. Thanks to this forum I learned the code to reseet the machine. The washer started fine and ran through a very long cycle. I opened it after about 2 hours to see if the cycle was done. Steam came out, and it seemed to just be runnning long so I closed the door. The next morning water is pooled in the bottom of the machine and all systems are dead. I checked the circuit box and no problems there. I took the panel off and made sure all connections were solid. I tried the secret codes and got nothing.
So do I call for service, or start replacing parts? Any suggestions?
Tim
abadfish66
#2 Posted : Wednesday, November 19, 2008 8:01:29 AM(UTC)
abadfish66
Check the easy things first. Make sure there is power at the junction box of the dishwasher. Make sure your door switches are working properly.
mptimoneil
#3 Posted : Wednesday, November 19, 2008 8:10:43 AM(UTC)
mptimoneil
Could a bad door switch cause the entire unit to be dead, with no lights on the panels? The switch came apart when I was replacing the handle, but it went right back together and makes the same clicking sound when activated.
Also, do I have to pull the unit out to get at the junction box or is it accesssable below the front panel?
v2k04
#4 Posted : Wednesday, November 19, 2008 9:02:34 AM(UTC)
v2k04
There's a microtemp clipped to the control board or thermal whatever ya want tot call it it will blow if it overheats as well sounds like the unit isn't getting water either
