Oven is a GE Profile xl44, model number JGBP90MEB2BC. Oven will not heat up. Broiler does work. Can I test the heating element? I there a PDF for this oven? Thanks, Bernie
Here's the parts breakdown Model JGBP90MEB2BCCheck the ignitor first is if it glows hot (yellow hot) Nat
