I would like to replace the water pump on this washer. The pump seems to be attached to the motor . I have found out that the motor has been discontinued. Can I just replace the pump on this washer. Or is there a way to remove the pump and replace it. .What are my options? NBRUNO
The pump is attached to the motor with 2 metal straps. Remove the straps, and the pump lifts off the motor.
Why are you wanting to replace the pump?
I was able to remove the pump from the motor . If I order the pump and the bottom part of the pump will it work properly?
You never said what is wrong, so I have no idea if it will work. What problem are you having?
Originally Posted by: abadfish66  You never said what is wrong, so I have no idea if it will work. What problem are you having? The pump was leaking.
If you remove the front tub bolt and then raise the front part of tub and jam a screwdriver in the hole where the bolt was so the bottom edge of outer tub rests on the screwdriver it will give you more clearence to get the pump in and out the bottom part of what you are calling the pump is the drip shield
