Gaya
#1 Posted : Monday, November 17, 2008 7:41:58 AM(UTC)
Gaya
When I pull out the start control knob, nothing happens. Has power, etc. Just worked one time and the next time it didn't.
magician59
#2 Posted : Monday, November 17, 2008 9:10:38 AM(UTC)
magician59
The first thing that normally happens is water fill. Do you hear a faint hum, or nothing at all, when you start the machine?
Gaya
#3 Posted : Monday, November 17, 2008 3:47:20 PM(UTC)
Gaya
Thanks for your response. No, there is nothing, no sound, just nothing. Can our washer be saved?
magician59
#4 Posted : Tuesday, November 18, 2008 5:00:36 AM(UTC)
magician59
It surely can be saved. The cause of the problem has to be discovered and remedied. Plug a lamp into the outlet the machine's plugged into. Does it work? If not, check the breaker for that outlet. If it does, you may need to replace the timer.
Dishwasher won't come on (Dishwasher Repair)
by Guest 6/18/2022 12:00:55 PM(UTC)
Washer won't come on (Washer Repair)
by Gusser 4/15/2009 6:05:04 PM(UTC)
