RJOHNSONJR
#1 Posted : Sunday, November 16, 2008 6:41:33 PM(UTC)
RJOHNSONJR
Ice maker does not appear to be cycling properly. It was making a noise and i removed the module cover and saw the dial was was "stuck" rotating back and forth approx a 1/4 inch. I manualy rotated the ice "raker?" and the tray filled with water and dial seemed to work correctly, for a while. Checked later and ice was frozen but not cleared from the tray and dial was "stuck" again. I again manualy rotated the raker to dump/eject the ice and again it filled with water,etc...
Doesnt appear to be any ice stuck in the workings anywhere to prevent it from cycling. Does the module need replaced or some other issue? Thanks.
#2 Posted : Monday, November 17, 2008 5:50:12 PM(UTC)
The ice maker module is bad. No doubt about it. I would recommend to replace the whole ice maker due to very low success rate of ice maker repairs.
- The part number for the ice maker is AP2984633
- The part number for the module is AP4359694
Here are the break down diagrams for the Whirlpool refrigerator Model ED25DQXBW00
RJOHNSONJR
#3 Posted : Monday, November 17, 2008 5:59:18 PM(UTC)
RJOHNSONJR
thanks for the reply Gene. ? though. If the module is bad why do u suggest replacing the whole unit? The rest of the "workings" seem fine. The module is only the piece under the cover held on by 3 screws,right? thx in advance.
#4 Posted : Monday, November 17, 2008 6:48:50 PM(UTC)
As I said in the previous reply there is very low rate of success on such repairs. In most cases there was more problems found later.
LG LDC24370ST Ice Maker Issues (Refrigerator & Freezer Repair)
by Guest 6/29/2024 8:55:44 AM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
Water Runs Too Long - Ice maker (Refrigerator & Freezer Repair)
by shfdyoung 6/11/2024 3:01:06 PM(UTC)
Bosch Ice Maker Dropping Ice Once Week (Refrigerator & Freezer Repair)
by Guest 5/31/2024 1:40:51 PM(UTC)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
Belarus eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
