Korrado
#1 Posted : Monday, November 17, 2008 1:58:27 PM(UTC)
Korrado
Hi there,
I have a Maytag Precision Touch Control 800 Electric Smoothtop, model MER5875RCB.
The front right triple element is not working properly. The inner-most element does not come on at all. The 2 other outer elements WILL turn on.
I have been told that it would most likely either be the switch or the triple burner. As I have been quote $180 for the burner, and been told it is not returnable, I want to make sure it is not the switch!
Any ideas how to diagnose? Thanks,
Mike
#2 Posted : Tuesday, November 18, 2008 1:30:30 PM(UTC)
Hi Mike,
You can find the instructions on how to check the element and/or switch as well as other parts in the tech sheets.
- The part number for the triple heating element is AP3873205 and you can buy it from APP just for $106.89
Korrado
#3 Posted : Tuesday, November 18, 2008 3:04:38 PM(UTC)
Korrado
Thanks for the reply Gene.
Do you have any specific instructions on replacing the triple element.
Thanks again,
Mike
#4 Posted : Tuesday, November 18, 2008 5:44:08 PM(UTC)
Mike,
Nothing special compare to all others in your range besides it has more wires connected. You have to lift up the top panel to access it.
kaliqcda
#5 Posted : Sunday, November 30, 2008 4:39:06 PM(UTC)
kaliqcda
Hi Mike,
I have the same problem with my MES5875BCS - a Maytag Slide In Range. Could you update or keep us posted with your progress? I just wanted to have an idea of what am I up against.....
thanks,
Joseph
#6 Posted : Monday, December 1, 2008 3:29:37 AM(UTC)
kaliqcda
#7 Posted : Monday, December 1, 2008 4:44:19 PM(UTC)
kaliqcda
Thank you very much Denman!!!!!
Guest (4)
