oven get too hot and does not keep temp. Just turns on elements and stays on. Replaced thermostat and still does same thing.. I need to check wire diagram of the thermostat. Any out there.. Thanks
I can send you the service manual if you want to send me an email.
Nat
Thanks for the manual troubleshooting guide. I did the checks on the selector switch and found I have a short somewhere. just have to find it. Manual does not say what to do when you find a problem. Have you ever heard of this problem befor?
There's many issues that come up with different solutions.
Nat
Originally Posted by: libertyappl  There's many issues that come up with different solutions.
Nat I have an Idea that it maybe the broil cycle switch. Manual does not specify how to check this part whether it is supposed to be open or closed. It is closed. I already replaced the thermostat.
I'll have to ask Randy when he gets back, I'm not for certain.
Nat
ok Thanks Nat. I have a short on L2 and BR on the selection switch. It is only supposed to be on when the broil option is selected. When i disconect the wire for BR the selector switch works like it is supposed to. I will be back soon. This is from the troubleshooting guide you sent me page 4-38 . Thanks.
Randy hasn't gotten back to the office yet...had a long drive from last service call. That's what we get for living in the boonies :o Nat
