Bruce Barrett
#1 Posted : Monday, November 17, 2008 9:31:17 AM(UTC)
Bruce Barrett
I ordered a new burner for my gas stove. I thought the old one was bad when I removed it due to 2 splits on the underside of the burner. The new one I received from you has 1 split on the underside. This may be the way it is made. Anyway,the problem I have is that the flame comes on sometimes and then it may go out and it takes a real long time to light. Now the igniter stays on all the time. Sometimes when the oven is set on 400 the igniter comes on and no flame for a long time and then you can smell gas in the kitchen. The stove is old but I would like to repair if possible.
Thanks, Bruce
v2k04
#2 Posted : Monday, November 17, 2008 12:34:55 PM(UTC)
v2k04
the splits is how the gas flows to both sides put a clampon amp probe and see what it draws the ignitor should always stay on even when it's lit. so if it goes out again it will relite
Bruce Barrett
#3 Posted : Monday, November 17, 2008 12:44:22 PM(UTC)
Bruce Barrett
HOW MANY AMPS SHOULD IT BE DRAWING? i WILL CHECK IT TONIGHT AND IF ITS DRAWING THE CORRECT AMOUNT WHERE DO WE NEED TO GO THEN?
Bruce Barrett
#4 Posted : Monday, November 17, 2008 1:01:25 PM(UTC)
Bruce Barrett
Something i failed to mention is sometimes when you turn on the oven and the igniter comes on and glows. Not everytime but you smell gas odor in the kitchen.
libertyappl
#5 Posted : Monday, November 17, 2008 1:03:15 PM(UTC)
libertyappl
My guess would be the ignitor isn't hot enough to light the gas.
Nat
v2k04
#6 Posted : Monday, November 17, 2008 1:27:48 PM(UTC)
v2k04
if its round 2.5 if its flat 3.2-3.6
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
Thermador Gas oven won't light (Oven Repair (including Ranges and Cooktops))
by Guest 8/1/2023 8:48:27 AM(UTC)
How to diagnose Thermador gas oven PG366BS not heating? (Oven Repair (including Ranges and Cooktops))
by Guest 4/12/2023 12:28:01 PM(UTC)
Frigidare gas oven (Oven Repair (including Ranges and Cooktops))
by Guest 3/19/2023 10:34:40 AM(UTC)
Whirlpool Gas Oven - GW397LXUS06 (Oven Repair (including Ranges and Cooktops))
by Guest 3/16/2023 6:39:44 PM(UTC)
WFG231LVQ0 Gas Oven F2 Code (Oven Repair (including Ranges and Cooktops))
by jwclteer 2/1/2023 12:42:38 PM(UTC)
Gas oven won’t light (Oven Repair (including Ranges and Cooktops))
by Guest 12/22/2022 1:10:46 PM(UTC)
GE gas oven not maintaining temperature after preheat completes (Oven Repair (including Ranges and Cooktops))
by Guest 12/2/2022 7:33:59 PM(UTC)
Kitchen aid gas oven won’t heat up (Oven Repair (including Ranges and Cooktops))
by Guest 11/24/2022 4:29:09 AM(UTC)
KitchenAid KGRS807SSS02 30" Freestanding Gas Oven Convection - F6 E0 Lost Communications Error (Oven Repair (including Ranges and Cooktops))
by Matthedges 8/9/2022 4:59:40 AM(UTC)
Whirlpool W10198618A Gas Oven Won’t stay lit (Oven Repair (including Ranges and Cooktops))
by Guest 1/10/2022 3:49:35 PM(UTC)
gas oven blowing out (Oven Repair (including Ranges and Cooktops))
by searkcraig 12/25/2021 8:04:53 AM(UTC)
gas oven ignitor cost (Oven Repair (including Ranges and Cooktops))
by Guest 10/30/2021 5:43:49 AM(UTC)
Whirlpool gas oven lights but won't heat to temperature (Oven Repair (including Ranges and Cooktops))
by mikepol2 10/28/2021 5:13:06 AM(UTC)
GE Gas Oven Control panel blank (Oven Repair (including Ranges and Cooktops))
by sjohnson1161 3/17/2021 6:23:41 PM(UTC)
