TonyP
#1 Posted : Sunday, November 16, 2008 1:18:22 PM(UTC)
TonyP
Hello,
The control panel appears to be working normally.I'm thinking its either the control panel or the gas valve. Thanks in advance.
libertyappl
#2 Posted : Sunday, November 16, 2008 3:02:31 PM(UTC)
libertyappl
You may want to check for a broken or chewed wires.
Nat
TonyP
#3 Posted : Monday, November 17, 2008 12:00:41 PM(UTC)
TonyP
Hello,
I checked for broken or fraid wires didn't see anything.
I purchased a new ignitor .
Since it was easier to access the broil ignitor I decided to change that one.
Power to ignitor before attaching ignitor was 95.7 volts.
Power after attaching was 0.
Also I disconected the leads from broiler to gas valve to test valve continuity it tested .001.
I'm stumped.
Thank you
libertyappl
#4 Posted : Monday, November 17, 2008 12:14:18 PM(UTC)
libertyappl
Locate your tech sheet, it should be in the control panel, start tracing the power thru the harness. Also check all the connections for the harness.
Nat
