Hello, The control panel appears to be working normally.I'm thinking its either the control panel or the gas valve. Thanks in advance.
You may want to check for a broken or chewed wires.
Nat
Hello, I checked for broken or fraid wires didn't see anything. I purchased a new ignitor . Since it was easier to access the broil ignitor I decided to change that one. Power to ignitor before attaching ignitor was 95.7 volts. Power after attaching was 0. Also I disconected the leads from broiler to gas valve to test valve continuity it tested .001. I'm stumped. Thank you
Locate your tech sheet, it should be in the control panel, start tracing the power thru the harness. Also check all the connections for the harness.
Nat
