lenny prezorski
#1 Posted : Monday, November 17, 2008 6:08:33 AM(UTC)
lenny prezorski
The clutch on my GE washer slips so I'm planning on replacing it. I'm looking for help on completing the repair. It appears that I have to remove the drive belt and then pull the clutch off of the motor. I've been fooled by other "easy" repairs so I'm looking for advice or any tricks that will ease the repair. Thank you.
v2k04
#2 Posted : Monday, November 17, 2008 6:16:12 AM(UTC)
v2k04
Slip off belt, remove the 4 3/8 nuts holding motor, remove motor,.remove clip off motor shaft that holds clutch on, remove clutch, (Sometimes you need a small gear puller) assemble in reverse order
lenny prezorski
#3 Posted : Monday, November 17, 2008 6:59:19 AM(UTC)
lenny prezorski
Thank you. This is indeed an easy repair.
Clutch replacement (Washer Repair)
by lumberwedge 8/14/2015 2:39:49 AM(UTC)
Maytag Neptune Washer Clutch Replacement (Washer Repair)
by helplessm355 4/16/2015 5:22:16 PM(UTC)
Kenmore Elite clutch replacement (Washer Repair)
by Nottheaveragejoe 12/11/2014 5:21:23 PM(UTC)
washer clutch replacement (Washer Repair)
by mlovett22 6/8/2013 11:56:58 AM(UTC)
by cjohns 8/30/2011 4:51:49 PM(UTC)
Kenmore washer "throwing" fabric softener after a clutch replacement (Washer Repair)
by sjv 1/29/2011 3:48:27 AM(UTC)
maytag fav6800aww washer clutch replacement (Washer Repair)
by pandsshearer 3/5/2009 11:44:36 AM(UTC)
Whirlpool Clutch Replacement (Washer Repair)
by bermudabye 1/7/2008 6:07:34 AM(UTC)
