wallaby
#1 Posted : Tuesday, May 24, 2011 2:53:13 PM(UTC)
wallaby
The small side oven will not turn on - the red ON light is not on either. Neither element will turn on. The main oven is working perectly. What is the problem and what part do I need?
#2 Posted : Wednesday, May 25, 2011 3:44:29 AM(UTC)
Here are your parts includes a wiring diagram.
Replacement parts for FRIGIDAIRE PLEF489CCE Frigidaire/electric Range | AppliancePartsPros.com
Here is a better wiring diagram. The left oven is lower right corner of the diagram.
http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318045328.pdf
Could be that the safety thermostat is open. I think this is Item 219 in Section 2 of the parts.
May also be the actual temperature control thermostat which I think is Item 12A in Section 1.
May even be a burned off wire.
Below is a manual which should help with the repair
Frigidaire 30 Inch and 40 Inch Electric Freestanding Ranges (5995362828) Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
You could unplug the unit and check the above with a meter.
