brian emerson
#1 Posted : Sunday, November 16, 2008 8:50:22 AM(UTC)
brian emerson
the light inside dryer works no power to the black wire on the push to start swich
#2 Posted : Sunday, November 16, 2008 7:13:19 PM(UTC)
Hi Brian,
The first thing I would do is check the circuit breakers and make sure there is 240VAC at the dryer outlet.
If there is nothing wrong then check the thermal fuse (behind the back panel) for continuity.
- The part number for the thermal fuse is AP3132867
Maytag Neptune Dryer wont do anything (Dryer Repair)
by heg0423 8/21/2013 10:26:37 PM(UTC)
