Wash arm does not spin and water is not pumped out. The timer seems to be functioning okay. I don't hear any hum from the motor when I think I should and checking I find 120 volts in. Also, when unit is off I find no motor resistance in those wires. Am I correct in assuming a failed motor? If so should I replace just the motor or the pump-motor unit? I got this dishwasher used about a year ago at a recycle store and don't know its age but it looked newish. Is it worth repairing??
I could not find anything on a 48BA, the following is for a 45BA. The pumps will be the same Replacement parts for General Electric GSD720P-45BA | AppliancePartsPros.com[COLOR="DarkRed"]I don't hear any hum from the motor when I think I should and checking I find 120 volts in. Also, when unit is off I find no motor resistance in those wires. Am I correct in assuming a failed motor?[/COLOR] Yes it does sound like the motor is toast. [COLOR="DarkRed"] If so should I replace just the motor or the pump-motor unit?[/COLOR] I would replace the motor and pump. [COLOR="DarkRed"]I got this dishwasher used about a year ago at a recycle store and don't know its age but it looked newish. Is it worth repairing??[/COLOR] It may be if it is in great shape but only you can answer that. The motor/pump is on the first page of the parts. At over $130.00 it is a pretty hefty investment into it. |
THIS FORUM IS DEAD!!!!!!! |
